Home › Forums › All Things 750 Twin › Projects and Progress › Progress Reports › Uprated progressive fork springs and clutch springs
- This topic has 3 replies, 1 voice, and was last updated 6 years, 9 months ago by beachcomber.
16th April 2017 at 11:46 am #4140beachcomberParticipant
Over the years I have had many speciality springs made and latterly for http://www.ramshox.com. – site is being replaced – but it will give you an idea.
I will be needing upgraded items for my Glemseck project.
Many of you will know that Redditch is the spring capital of the UK – remember “Terry’s Springs” ? You will if you’ve rebuilt many Brit bikes – best valve springs available – allegedly.
My tame spring man will make me just a set if I ask nicely, but as with the other springs now available from Realm Engineering, makes sense to have a batch made. Gets the cost down and everyone benefits from a bespoke product at an off the shelf price.
So, any interest ?&l
Particularly those peeps with the dreaded “air assist” front forks !
I did a replacement progressive fork spring for my Vindicator Cafe Racer [ Yamaha TR1 based }and it transformed the handling – not to mention a simplified set up and maintenance.
So here’s what I plan to investigate:
Progressive fork springs
Uprated clutch springs – say 25%- 30%Anyone interested ?
- This topic was modified 7 years ago by lonesome. Reason: Weird html additions. Was this copy/pasted from somewhere else?
20th April 2017 at 11:51 am #4192beachcomberParticipantI just paid a visit to my tame spring man.
Absolutely NO problem. He has ample stocks of the correct grade high quality spring wire to make both clutch and fork springs.
I WILL go ahead with the clutch springs anyway. I need to order 100 springs minimum, which is only 20 bike’s worth ! Just as a matter of interest I’ll check the price availability of OEM clutch springs.
The fork springs are another matter, as the unit cost is significantly higher – not huge, but I have to be certain there is interest before I commit to placing an order. However, I expect a unit cost of less than £75 / pair with an initial order of 50 springs.
Like I said – any interest ??
16th May 2017 at 8:19 am #4303beachcomberParticipantI’ve had no interest in either sets of springs – so that’s a non starter.
I’ve found some uprated Barnett clutch springs, but they’re only about 10% uprated – not really what I need for the Glemseck project, but cheap enough for the TD [ £20 / set ].
I’ll probably pull the old pals act and get my tame spring man to wind up a set of progressive springs for my project. He owes me big time for work I’ve put his way – so time to call in the favour !
5th July 2017 at 11:53 am #4404beachcomberParticipantSomebody want to send me a sample clutch spring ?
I’m getting 5 sets made for myself [ 1 x TD , 1 x Glemseck and 3 spare sets for Glemseck ].
These will be 30% stronger than stock, and 10% more than the Barnett ” Hi Performance” items.
If there is any interest before I pull the trigger on these I can add to the order. Has to be in increments of 5 sets to keep the prices right.
