- This topic has 56 replies, 8 voices, and was last updated 7 years ago by .
Home › Forums › All Things 750 Twin › Projects and Progress › Progress Reports › my 750 so far
i dont have any plans i just got a few pictures of different lifts and went for it myn has been made to fit in a pit in my garage and its not square so pointless giving you any measurements other than the length which is 2100 and i used 40mm box with 20mm steel tube for the bolts to run in and nylon wheel,have a look at MIKEONABIKE link his wood lift that can be put and down is good
So i have her looking how i like just got to change the clocks, now time to strip and paint
frame now powder coated dark grey
engine been tarted up a bit i had to take the head off to Helicoil spark plug thread a first for me but was not to hard
so time to get that heavy lump back in the frame without bashing it to bits
Shinny 😉
That is coming along quite nicely.
Grey frame??? MMM kinda like that. Engine looks differently tasty. I’m interested to see where this is going . . .
Looks good !
Will follow your further progress 😉
sprayed the engine casings last weekend in matt black then satin lacquer, what aload of shite they turned out just did not look right so heres a pic of the clutch side in just matt black and polished points cover that needs a bit more polishing so hope you all like
cheers dave
here’s a pic with the lacquer on same casing i didnt even let it dry just attacked it with paint remover
A LITTLE MORE DONE ON THE FRONT END
Looks like it’s going to be a stunner mate.
I Love that seat.:-)
Thanks Tango i hope so, i have my tank to spray as well. Im gutted for you having to do yours again it was looking fine n shiney
back wheel on and left hand engine cases, ive just sprayed my rear caliper so that can go soon.i need to get a digital speedo and then wire it in,any one on here done one?
The engine casings look miles better in a satin black finish.
Awaiting further progress with baited breath . . .
