- This topic has 10 replies, 3 voices, and was last updated 7 years, 8 months ago by .
Viewing 11 posts - 1 through 11 (of 11 total)
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › Fuel petcock
I’ve managed to break the lever on my B3 fuel tap ( used to Honda reserve position) I was thinking about replacing it with a Harley tap as mentioned elsewhere. If anyone has done this how did they get round the single outlet ?
Hi Old Red Eyes
If I am correct the Harley tap has been used when changing the 38mm carbs to the GPZ 34mm which only require a single fuel supply.
However I do think I’ve seen the Harley style with twin outlets.
Alternatively I can help with a replacement lever for your tap.
Interested in your help.
Not the cheapest ones, but great:
http://www.pingelonline.com/prodcat/fuel-valves.asp
http://www.pingelonline.com/motorcycle-fuel-valves/dual-outlet-3311-d-ch.asp
You may use a fuel tap with single outlet instead and a “T-shaped” connector between fuel tap and carbs.
Thread size at B-tanks is M22x1.
Thanks Michael they certainly look good.
I can supply you with either a replacement lever or a full tap assembly if you are interested.
Would like a replacement lever. Let me know details of how we go about it . Thanks.
PM Sent
Top man.
Received today thanks.
Your welcome and thanks for letting me know.
