- This topic has 1 reply, 2 voices, and was last updated 7 years, 11 months ago by .
Home › Forums › All Things 750 Twin › Archive › KZ750B1 Forum › Float bowl adjustment
Hi. Just posted some questions on the How to Fix It section. I need the measurement for float bowl
adjustment. Had not seen this KZ750B section.
Sorry.
Thanks.
Hi Alfredo
I have attached a picture showing the only fuel height dimensions I am aware of. It seems a bit primitive and is a bit of messing about but it does work.
With regards to your other questions, fitting pods reduces the resistance of the air being sucked through the carbs compared to the set up with the airbox. This in turn reduces the suction of fuel by the carb from the bowl. Therefore it is most likely you will need to increase the jet sizes to allow more fuel to be included in the mixture.
I cannot suggest the size of increase as I have not carried out this conversion but I would recommend speaking to a carb specialist who if worth his corn will be better equipped with knowledge to guide you. I would expect any adjustment would be as follows;
Pilot jet + 3 to 5
Main jet +10 to 15. This is very dependant on the pod resistance AND the exhaust resistance.
I hope this will be of help to you.
