- This topic has 4 replies, 4 voices, and was last updated 10 years, 1 month ago by .
Home › Forums › All Things 750 Twin › Technical Garage › Tips and Ideas › caliper pistonpusher
to push the piston back when bleeding the brakes. drill and tap a 6mm thread in an old fixed brake pad open the bleed valve a screw will push the piston to the back
Good call there. I would not have thought of that.
Hi Chris,
very good idea !
I just spent some money (30,-Euros special price) for this tool in workshop quality.
http://www.louis.de/_30d26f2d75a60443d2c04eba6a1a30fcea/index.php?topic=artnr&artnr=10003009
Main reason was to be able to “reset” the pistons in a four piston fixed caliper on my girlfriends Yamaha YZF600R.
Could not imagine how to handle four pistons at the same time 🙂
I’ve just used a screwdriver before?
started the piston moving then just pushed it back with my thumbs?
Hi Tango,
not to bad with the single piston caliper of a Twin.
As long as you can push the piston with your fingers, everything is ok.
Used my tool the first time today to reset the pistons in a Z750B2 rear brake and it worked perfectly 🙂
