- This topic has 5 replies, 2 voices, and was last updated 6 years, 9 months ago by .
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › Battery not charging
I dont seam to be able to track down why my battery wont charge
this severely limits how far i can get from home before i have to return and charge the battery
I know this is not much to go on
I was hoping for a bit of brain storming so i will leave all options open in case there is something obvious I have forgotten
there usually is
thanks in advance
There are a number of possibilities here Gringle. I am away tomorrow till Tuesday but will be with you to help from then.
After talking to the kaptain last night and looking at a clearer wiring diagram on the new site I think i have figured out my charging problem
I will keep you posted
Do know how you get on.
It is good to see the ‘NEW’ site which will be running properly soon is usefull
looks like i had a wire wrong
I put it right but the weather is not good so I have not tested it yet
I will probably start posting on the other site from now on
Good your on the case.
It is fine to use the new site as very soon it will be the main site. That goes to everyone else too
