AIR VALVE SWITCH
Home Forums All Things 750 Twin Technical Garage Tips and Ideas AIR VALVE SWITCH
  • #5732
    DABBLER
    so im thinking of putting KN filters on doing away with the airbox as im going down the brat style ish BUT what does one do with the two pipes from the rocker cover to the air valve switch i was thinking a bit of pipe to a KN filter or even a filter directly on to it any one done this or is it a bad idea
    cheers dave
    #11886
    Kaptainkwak
    This pipe system is not required here in the UK. I have remove all the system from mine and fitted blanking plates. Before I got the blanking plates I simply disconnected the pipes from the airbox and joined them together with a piece of copper pipe.
    #11887
    Michael
    Hi Dave,
    use Google Chrome as webbrowser and get this page translated for further information:
    Dynojet kit should work with CSR carbs as well, except that mixture screw can not be adjusted and low revs range may be a little lean.
    http://www.z750twin.de/vergaser.htm
    DABBLER
    thank for the info guys
